can't record cassette with Behringer UCA202
Help for Audacity on macOS.
jeffhecht
Operating System: macOS 10.14 Mojave
Re: can't record cassette with Behringer UCA202
Post by jeffhecht » Fri May 14, 2021 12:57 am
I hit this bug again today, after having updated Mojave last night. It may be the first update I've run since I started using Audacity, and I hadn't expected the bug to reappear, but when I looked up the error code ad searched the boards, I found the fix and it worked again.
