Catalina audio problems
Help for Audacity on macOS.
jng
Post by jng » Fri Jan 22, 2021 8:48 pm
Using iMac Catalina and Audacity 2.4.2. When I import my .aup files from my previous Mac there is no audio in the tracks window and of course no sound. Is there a fix for this or are all my older .aup files gone forever? The data folders are intact.
Thanks for any help!
billw58
Re: Catalina audio problems
Post by billw58 » Fri Jan 22, 2021 11:01 pm
The AUP file and its associated "_data" folder must be in the same folder.
-- Bill
jng
Post by jng » Sat Jan 23, 2021 2:13 am
They are, that's what confuses me. Thanks though.
jng
Post by jng » Sat Jan 23, 2021 3:03 am
I wonder if it's because I recorded the tracks on an earlier macOS and possibly an earlier version of Audacity. But not more than a year old at most. That computer fatally crashed so I'm playing the tracks from a Time Machine backup. I guess I just have to kiss the files goodbye.
billw58
Post by billw58 » Sat Jan 23, 2021 3:48 pm
If you get no error message about missing block files then it seems the files containing the audio contain silence.
Try opening a new project and dragging one of the AU files (inside any _data folder) to see if the files contain silence or audio.
-- Bill
