I've used Audacity 2.4.2 with OSX 10.14.6 and it's always worked just fine. This afternoon I recorded myself on voice/guitar and flute through my Xneyx 802 mixer via USB without a hitch. I then went to put down another track with my bass. It registers on the mixer, it shows on the computer sound input but lays nothing down in Audacity. Not through a direct connection through the line input or through a balanced mic input on a DI box. Everything else seems to work. I then recorded by putting a mic to my practice amp but the tone isn't as good. I was able to record bass last time I multi tracked with the bass through the line input on the mixer. All that's different is I've changed the battery on my Rockbass Corvette 4A.
Anyone know what's going on?
Bass won't register directly
TheMadMick
- Operating System: macOS 10.14 Mojave
Re: Bass won't register directly
A shot in the dark from a non-Mac guy. Is the bass on channel 3? Do you have Audacity set to record in mono or stereo? Check your Device Selection Toolbar: https://manual.audacityteam.org/man/device_toolbar.html
TheMadMick
Sorry for my laggardly response to a helpful comment.
I'll give that a try.
Thanx.
Thanx.
