Audacity crashes
Help for Audacity on macOS.
angelique.j
Audacity crashes
Post by angelique.j » Mon Jan 04, 2021 2:27 pm
Hello,
I am using macOS High Sierra version 10.13.6 and audacity2.4.2
I am doing a podcast and Audacity keeps crashing and the app closes after i try to edit something.
I have read other similar question/answers on the forum and tried the solutions given but it hasn't worked.
Any suggestions?
Thank you!
Capture d’écran 2021-01-04 à 14.33.58.png (1.04 MiB) Viewed 283 times
billw58
Re: Audacity crashes
Post by billw58 » Mon Jan 04, 2021 5:07 pm
Could you post a screen shot of your project before the crash?
Are any of your tracks at a sample rate of 32000?
-- Bill
angelique.j
Post by angelique.j » Tue Jan 05, 2021 11:34 am
Yes i think they all are at a sample rate of 32000. what should i change them to?
Capture d’écran 2021-01-05 à 12.30.01.png (153.76 KiB) Viewed 257 times
Post by steve » Tue Jan 05, 2021 11:37 am
Set the "Project Rate" (lower left corner of the main Audacity interface) to 44100.
Then "Select menu > All".
Then "Tracks menu > Resample" and resample to 44100.
angelique.j
Post by angelique.j » Tue Jan 05, 2021 4:20 pm
i did exactly that and it works again!
thank you so much
