Hello. Apologies in advance if this is the wrong board or if this issue has already been reported.
Cheers and thanks for all your work on this amazing app.
* What exactly you are trying to do
(also) * What is preventing you doing that, including the exact text of any error messages given.
If I try to change the range of a time track by clicking the "Time Track" dropdown, then selecting "Range...", then entering a value and proceeding by pressing the return key (to choose the default "OK" button), the range does not change. However, using an actual enter key (fn+return on laptop or full keyboard enter), or mouse clicking the OK button does commit new values. FYI, I spot-checked two similar cases and this issue did not occur: changing the time track name and an audio track rate.
* The exact three-digit version of Audacity you are running for example 2.1.3. You can always find this by clicking Help > About Audacity in the program (or Audacity > About Audacity if you are on a Mac computer).
2.4.2
* If not downloaded from our website, where you obtained Audacity from
DMG from site, sha256 verified 4730abe5b59d9c3dd000fde22d7037af6e6019a4305195a3e4e714f6c9f6380a
* What operating system you are running including the exact version (for example Windows 10, Windows 8.1, macOS 10.15.7, Linux Ubuntu 20.04).
System Version: macOS 10.15.5 (19F101)
Kernel Version: Darwin 19.5.0
* If Audacity is crashing or freezing
N/A
Minor but confusing bug, time track range doesn't change using return key on laptop
billw58
Re: Minor but confusing bug, time track range doesn't change using return key on laptop
I can confirm this on my iMac. I think you've found a bug. Thanks for reporting it.
-- Bill
-- Bill
