Troubleshooting Help
Help for Audacity on macOS.
Kjudd13
Operating System: macOS 10.12 Sierra
Post by Kjudd13 » Thu Dec 31, 2020 4:11 pm
I am a new user.
Hardware:
Scarlett 2i2 3rd Gen Audio Interface
Samson C01 Condenser Microphone
Mac Computer
Software:
Audacity
Problem - getting error message "Error opening recording device. Error code: -9997 Invalid sample rate"
My preferences for Audacity seem to be on 48k which is the same for my Scarlett settings.
Any recommendations for a new user to clear this hurdle?
Thanks!
jademan
Forum Crew
Re: Troubleshooting Help
Post by jademan » Fri Jan 01, 2021 10:08 pm
I am a new user.
Hardware:
Mac Computer
Software:
Audacity
Thanks!
So while we are waiting for our Mac experts to show up, see here for ideas to ponder: viewtopic.php?t=114810
also: viewtopic.php?t=103452
Does audacity have permission to use your microphone ?
Post by kozikowski » Fri Jan 01, 2021 10:43 pm
Screen Shot 2021-01-01 at 2.36.18 PM.png (7.44 KiB) Viewed 426 times
Which version? Audacity (upper left) > About.
This is the Sierra OS. It didn't ask for permissions. I'm running High Sierra (later) and it doesn't.
Mac Computer
Which Mac and how old?
Kjudd13
Post by Kjudd13 » Sat Jan 02, 2021 2:41 pm
Audacity 2.4.2
Which MAC? IMAC 21.5 inch late 2012 running Catalina OS
Where do I check if audacity has permission to use the microphone?
Thanks!
jademan
Forum Crew
Post by jademan » Sat Jan 02, 2021 3:10 pm
... running Catalina OS
Thanks!
for Catalina, see here: https://support.apple.com/en-gb/guide/m ... /mac/10.15
