Playback track ids
Help for Audacity on macOS.
Snuglebum
Playback track ids
Post by Snuglebum » Wed Dec 30, 2020 6:32 pm
I have imported a mix cd, audacity has separated the tracks, I have put them back together and the mix runs fine. But I want to add the track ids back in so when I play it back on an iPod or similar, you can skip to the next track in the mix. I will be exporting the finished project as a MP3
Can anyone help please?
Many thanks
billw58
Re: Playback track ids
Post by billw58 » Wed Dec 30, 2020 11:36 pm
Is this what you're trying to do?
-- Bill
