Audacity is recommended for languages studies.
I downloaded Audacity 2.1.1 on my MacBook MacOS High Sierra 10.13.6.
I cannot get the Menu line (File, Edit,...).
What is the problem?
How to get the Menu line
Re: How to get the Menu line
The current version of Audacity is 2.4.2. It is available via the Audacity website: https://www.audacityteam.org/download/mac/
I'd suggest that you completely remove your current version, and install the official release version.
Like other apps on Mac, when Audacity 2.4.2 is the front window, the menu is at the top of the display.
Ok. Thank you.
I found it.
I had a screen copy from someone else but it was not for a Mac and I went lost.
I found it.
