Sample rate
Help for Audacity on macOS.
NickM2
Sample rate
Post by NickM2 » Tue Dec 29, 2020 11:18 am
Hi there,
I have just tried to record some stuff but got an error code saying : Invalid sample rate.
How do I fix this ?
Many thanks
NickM2
Re: Sample rate
Post by steve » Tue Dec 29, 2020 12:34 pm
What are you trying to record and what equipment are you using?
Are you able to import an audio file into Audacity and play it?
jademan
Forum Crew
Re: Sample rate
Post by jademan » Wed Dec 30, 2020 12:34 pm
Hi there,
How do I fix this ?
Many thanks
NickM2
Not a Mac guy here. This error can be a catchall error indicating a host of different issues. Possibly the Sample Rate (lower left-hand corner) doesn't agree with what Mac or the device are presenting. Or with a previously recorded track.
Sometimes the issue can be cleared by resetting Audacity or the device or the PC. In some cases the problem can be corrected by updating the software drivers or the OS. BTW, are you on 2.4.2?
I know you want to try to fix this problem yourself. But if you can't, try to answer steve's questions. :D
I hope this helps. :D
