16 bit or 24 or 32 float for ACX?
Help for Audacity on macOS.
SoniaGabriella
Post by SoniaGabriella » Sun Dec 27, 2020 10:34 pm
Is there any connection between the noise floor and 16, 24 or 32 bit recording?
Thanks!
Sonia
Re: 16 bit or 24 or 32 float for ACX?
Post by kozikowski » Sun Dec 27, 2020 11:07 pm
Missed one. Audacity operates in 32-bit, floating. It does that so there is no sound damage no matter which effects you use or in what order.
The one place where Audacity actually creates noise is sound file export. When you make a sound file from your show, Audacity has to convert from 32-bit floating back to normal sound files. It helps that process by adding a tiny bit of special background noise to the show. It's way quieter than performance noise.
Post by steve » Mon Dec 28, 2020 12:07 am
In short, the more "bits", the lower the "possible" noise floor.
In real life, the actual noise floor is considerably more that the "lowest possible" for 16, 24 or 32 bit.
For technical reasons, it's best to work in 32-bit float, then export in the required format (usually 16-bit).
That's the practical information. Wikipedia has pretty good account of the technical information: https://en.wikipedia.org/wiki/Audio_bit_depth
SoniaGabriella
Post by SoniaGabriella » Mon Dec 28, 2020 8:52 am
Thank you everybody for your help!
