I have been searching and searching, and it seems like this is possible and there was once a list of devices that makes this possible, but I’m unable to find such a list.
What interfaces would enable me to do this?
2013 MacBook Air.
Thanks
Record four tracks at once
quichenight
Re: Record four tracks at once
There's this topic, but much of the info is now quite old: viewtopic.php?f=27&t=38626quichenight wrote: ↑Sat Dec 19, 2020 7:06 pmthere was once a list of devices that makes this possible
quichenight
Know of an interface still in production that can do it?
On Linux (I use Linux), these are said to work, though I don't own any of them, so I'm not able to test on Mac (or any other platform).quichenight wrote: ↑Sun Dec 20, 2020 3:40 pmKnow of an interface still in production that can do it?
Behringer UMC1820
M-Audio M-Track Eight
Presonus 1818VSL (No low latency monitoring under Linux)
Behringer UFX1204 and UFX1604
Allen & Heath ZEDi-10 FX
Alesis IO4 (Hard to find, Thomann sells these in Europe)
Native Instruments Komplete Audio 6
Behringer UMC204 and ADA8800
RME fireface UCX
MOTU Ultralite AVB
2nd gen Scarlett 6i6
