I'm not sure how to fix this hum issue. Despite the large amount of noise reduction I apply, there's still a lot of hum.
Help for Audacity on macOS.
5k33t3r
Operating System: macOS 10.12 Sierra
Post by 5k33t3r » Wed Nov 25, 2020 5:21 pm
So I've done two different samples: one of which went through a lot of noise reduction and normalizing, and the other of which went through even more noise reduction and normalizing. What you're about to hear won't sound like how it would be presented in a video, as I edited both of these clips in Premiere Pro to be quieter.
As a preface, my mic is a Blue Yeti X. It's pointed towards me at roughly a 45 degree angle. I sit slightly far away from my mic, and I bend down at a roughly 70 degree angle as I speak into the mic. Amplify and Noise Reduction were applied after Normalize.
Here's the first sample: https://voca.ro/18maqK9myGJt
The parameters are the following:
Normalize:
  • Remove DC offset is turned on.
  • Set Peak Amplification to: -5.0 dB
Noise Reduction:
  • Noise Profile is the beginning of the track (which has been deleted after the noise reduction process).
  • Noise Reduction: 16 dB
  • Sensitivity: 14.00
  • Frequency smoothing: 11 bands
Amplify:
  • Amplification: 0.6 dB
  • New Peak Amplitude: -3.3148 dB
Here's the second sample: https://voca.ro/14xu3MBWEVRm
Normalize:
  • Set Peak Amplification to: -8.0 dB
Noise Reduction:
  • Noise Reduction: 43 dB
  • Sensitivity: 20.00
  • Frequency smoothing: 10 bands
Amplify:
  • Amplification: 0.8 dB
  • New Peak Amplitude: -6.6822 dB
Here's the third sample: https://voca.ro/1c2itgs1SPz9
Normalize:
  • Set Peak Amplification to: -9.0 dB
Noise Reduction:
Amplify:
The third clip is definitely the clearest, but all suffer from an excess amount of hum, and when I try to play these tracks with music in the background, the hum is very distracting even when both are optimally balanced. Whether through Audacity or Adobe Premiere Pro (CC 2017), do you have any advice for solving this issue?
Alternatively, do you think my audio is perfectly fine and it doesn't need major changes?
As a final note, here's a clip of my voice (the second sample was used) with background music played over it (both tracks have gone through a lot of audio balancing in Premiere Pro): https://voca.ro/1h2n6t6Assjg
Trebor
Re: I'm not sure how to fix this hum issue. Despite the large amount of noise reduction I apply, there's still a lot of
Post by Trebor » Wed Nov 25, 2020 5:48 pm
... Here's the first sample: https://voca.ro/18maqK9myGJt
I can't hear any hum on that,
the outstanding problem is distortion* possibly caused by too much dynamic-range-compression.
You haven't mentioned applying compression, so possibly that's occurring before the sound gets to Audacity.
[ * not curable in post-production, need a do-over, not too loud: leave ~6dB of headroom]
looks like "Vocaroo 18maqK9myGJt" has been compressed
Vocaroo 18maqK9myGJt.png (31.43 KiB) Viewed 398 times
5k33t3r
Post by 5k33t3r » Wed Nov 25, 2020 5:50 pm
That's it? My issue is compression?
Trebor
Post by Trebor » Wed Nov 25, 2020 6:05 pm
IMO the issue is distortion, not hum.
It's possible to create such distortion using high compression ratio,
and/or the signal from the microphone was too loud (too hot) before any processing was applied.
Unfortunately post-production in Audacity or other software cannot reverse this distortion.
5k33t3r
Post by 5k33t3r » Wed Nov 25, 2020 6:18 pm
It should be known that I recorded this initially through QuickTime Player and then opened the mp3 file in Audacity. The effects I applied still worked, so it seems safe to say that I could still edit distortion and compression.
Nonetheless, I've found a different setup that doesn't cause anywhere near as much distortion, and now I'm about to edit it.
DVDdoug
Forum Crew
Post by DVDdoug » Wed Nov 25, 2020 6:19 pm
clipping (overload distortion) is a kind of dynamic compression (a bad kind, unless you're using it intentionally as an "effect").
I didn't listen because I'm at work....
I don't know how all of those angles add-up but you should be speaking directly into the front of the mic and you should be fairly close. If you are getting "plosives" (breath pops) it's OK if the mic is slightly-off to one side or you can speak slightly-over the top of the mic but it should be pointed at your mouth. And the mic should be set to cardioid (directional).
If you have to bend-over it might be better to position the mic differently or position yourself differently to make yourself comfortable. ;) (You might need a different/regular mic stand).
Post by kozikowski » Wed Nov 25, 2020 6:29 pm
Now post a sample that didn't go through anything.
https://www.kozco.com/tech/audacity/Tes ... _Clip.html
Read down the blue links. They're short.
You're using a Yeti-X? Did you figure out the convenient multi-function control knob? I couldn't either.
Yeti's are side-fire microphones. You should be speaking into the side grill just up from the company name. Not the round top.
Screen Shot 2020-11-25 at 10.23.54 AM.png (44.25 KiB) Viewed 394 times
Post by kozikowski » Wed Nov 25, 2020 6:32 pm
This is a good target for unprocessed voice recording.
It's possible you can't get there. If not, we need to address that first before you throw lists of processes at it.
5k33t3r
Post by 5k33t3r » Wed Nov 25, 2020 6:40 pm
Okay, how does this sound?
This time, I recorded with my mic only slightly tilted (at an estimated 78 degree angle) and with me not bending myself towards the mic. I've applied noise reduction and compression effects, and it sounds much clearer.
https://voca.ro/1dQ8NucaJrDa
If you think this is satisfactory enough, I'll then be editing it in Premiere Pro. Thanks for the assistance!
Post by kozikowski » Wed Nov 25, 2020 6:53 pm
If you're happy, we're happy. You're the Producer.
