Audacity on Big Sur
Help for Audacity on macOS.
billw58
Re: Audacity on Big Sur
Post by billw58 » Wed Apr 07, 2021 2:53 pm
What happens if you unplug the headphones and listen with the Mac's internal speakers?
-- Bill
SmeckoGeck
Post by SmeckoGeck » Thu Apr 08, 2021 5:04 pm
I think my issue had to deal with some VST plug-ins I had on my MacBook, because I think I got Audacity working again.
I also had an issue with GarageBand not responding whenever I opened it, and it dealt with some VST instruments I downloaded, so I deleted the VST plug-ins that were crashing GarageBand. And I feel like that also contributed to getting Audacity's playback functioning properly on my MacBook.
sensational fix
Post by sensational fix » Sun Apr 11, 2021 9:31 am
Hello there,
Just switched to Big Sur (11.2.3) and tried Audacity 3.0.0. I'm usually recording through decks and onto a mixer pioneer, but somehow I just can record on Mono, no Stereo options available in the new set up. Does anyone knows what is going on?
CHEERS!
David
Post by steve » Mon Apr 12, 2021 7:20 am
Please avoid double posting. I replied here: viewtopic.php?p=422646#p422646
mrmillercoach
Post by mrmillercoach » Fri May 14, 2021 4:13 pm
I recently updated to Big Sur 11.3.1. I am able to record new podcast episodes but I am not able to open any of my previous aup files.
I upgraded to Audacity 2.3.2 with no resolution. Yikes, this is a real problem for me.
Any suggestions on how to diagnose this problem.
mrmillercoach
Post by mrmillercoach » Fri May 14, 2021 4:26 pm
Never mind this was a DropBox incompatibilty on Big Sur. I needed to update DropBox.
Post by steve » Fri May 14, 2021 4:34 pm
Don't open Audacity while they are in your dropbox folder. (We have multiple reports of cloud drives causing serious problems with open Audacity problems).
Copy or move projects to a normal disk folder before opening in Audacity.
