Audacity on Big Sur
Help for Audacity on macOS.
PavProAnt
Re: Audacity on Big Sur
Post by PavProAnt » Mon Nov 23, 2020 5:17 pm
Just a big thank you for this thread. I have been hesitant to update only for the fact I don't want to worry about Audacity LOL
I will update now. Thank you!
billiekonze
Post by billiekonze » Mon Nov 23, 2020 5:17 pm
jademan wrote:
Sun Nov 22, 2020 7:43 pm
You need to update your audacity to the current mac version (64-bit) (2.4.2):
https://www.audacityteam.org/download/mac/
See also:
https://www.scu.edu/technology/computin ... s-big-sur/
I'm already on the current Mac version 2.4.2...
I just tested it, and it actually records just fine when using my built-in mic. It's only when I connect to my interface and pro mic that it just won't record. Thoughts on that?
Post by steve » Mon Nov 23, 2020 5:31 pm
Perhaps you can test your interface and pro mic with Garage Band.
elmvoice
Post by elmvoice » Sat Nov 28, 2020 2:40 am
I am on macOS Catalina 10.15.7
with Audacity 2.4.2
I was checking to see if there were know problems by upgrading to BigSur It appears as there should not be any issues with Audacity as there are with some other softwares
Thanks for everyones input!
ELM
GusMcC
Post by GusMcC » Sat Dec 05, 2020 12:26 pm
Hopefully this is the correct thread for this..........if not please let me know.
I've updated to Mac OS Big Sur and while Audacity seems to mostly perform well, every so often I have to close it down and reopen when I get a pop up error message saying "Error opening sound device. Try Changing the audio host, playback device and the project sample rate."
I use Bose USB audio as my preferred sound output and until Big Sur, I never got these messages. Any suggestions, and I have tried changing the audio host to the onboard Mac output and it works fine so it appears on Big Sur, to be some issue with the Bose output.
Screenshot
Post by steve » Sat Dec 05, 2020 12:44 pm
Check that the USB lead is securely plugged in at both ends and try using a different USB socket on your computer.
This problem may occur if the computer temporarily loses connection to the USB device. The computer will automatically reconnect if it can, but if that happens Audacity does not know that a new connection has been made and will still try to use the original connection - that leads to an error in Audacity because the original connection is no longer available.
If the problem occurs again, rather than restarting Audacity, try "Transport menu > Rescan Audio Devices", then check that the correct devices are selected in the Device Toolbar.
GTO_Audacity
Post by GTO_Audacity » Sun Dec 20, 2020 7:11 pm
I am noticing some bugs working in Audacity 2.4.2 and Big Sur.
Using the Time Shift Tool was definitely giving me problems.
I could highlight the clips, but many times I just couldn't time shift them.
A little cursing and some random clicking around (but usually rebooting) Audacity would get it to work.
Also noticed that applying filters (Amplify) and (Bass and Treble) caused Audacity to lock up many times.
Had to Force Quit to get out of those. This was particularly frustrating.
Other than that, it's working okay for me.
I am *not* a power-user though. Just a hobbyist.
GTO
waxcylinder
Post by waxcylinder » Mon Dec 21, 2020 11:29 am
Have you got the preference for "Editing a clip can move other clips" turned "off" in Tracks Behaviors preferences:
https://manual.audacityteam.org/man/tra ... ences.html
It is set "on" by default - if you turn it "off" it can stop clips moving when there is not enough room.
I can't make Time Shift fail on 2.4.2 or the latest alpha test build I have for 3.0.0 on Bug Sur macOS 11.1
I can't reproduce this behavior with 2.4.2 or alpha test 3.0.0
Peter.
Pascal07
Post by Pascal07 » Tue Dec 22, 2020 8:27 am
Bonjour,
je suis sur MAC OS 11.1, Macbookpro 2019.
Je n'arrive pas à enregistrer ma carte son avec Audacity 2.4.2 comme je le faisait avant, en utilisant l'appli Sound Syphon (elle ne supporte pas encore cet OS).
Auriez-vous une alternative?
Soit en utilisant une autre application tierce ou une manière différente de procéder?
Je remercie d'avance toute personne susceptible de répondre à ma demande,
Pascal
Admin - Google translation
I am on MAC OS 11.1, Macbookpro 2019.
I cannot record my sound card with Audacity 2.4.2 as I did before, using the Sound Siphon app (it does not yet support this OS).
Do you have an alternative?
Either using another third-party application or a different way of doing things?
I thank in advance any person likely to respond to my request,
spanghew
Post by spanghew » Wed Dec 23, 2020 12:48 am
So far, so good...except one problem: the playback indicator/bar used to move steadily across the screen regardless of how much I'd zoomed in. Now, when I zoom in, it "ticks" from point to point. This does not affect playback sound...but it means that I have less visual feedback of exactly where the playback is vis a vis the waveform.
Has anyone else noticed this? And is there due to be an upgrade specific to Big Sur soon?
