i've just created a new file and when I tried to export as mp3 the window which would normally allow you to do this opened but was blank. the same happened when I tried to save it. in case the file might be corrupt, I created a new file and cut and pasted the content of the original file to it and tried again but with the same result. i tried with an older file and the same thing happened. so ?
i could try closing Audacity and reopening but worried I'll lose the file I've just created and not been able to save.....
mac 10.11.16 aud 2.2.2
can't save/export
billw58
Re: can't save/export
Quit all other programs that are running. In doing so you should switch out of Audacity. Switch back into Audacity and try again.
-- Bill
-- Bill
