my first day with audacity
Help for Audacity on macOS.
sherrynadra
Operating System: macOS 10.14 Mojave
Post by sherrynadra » Wed Aug 26, 2020 6:40 pm
I made a simple recording. I pressed "stop." I listened to it. Now I want to start a second track. But when I hit the record button again, it goes to the same track, as though continuing the first track instead of starting a new one. What am I doing wrong?
Re: my first day with audacity
Post by steve » Wed Aug 26, 2020 6:44 pm
"Shift + Record button"
or
"Shift + R"
sherrynadra
Post by sherrynadra » Wed Aug 26, 2020 6:58 pm
Thank you. I knew it would be something stupidly simple!
Post by kozikowski » Wed Aug 26, 2020 7:04 pm
If you stack them like that, Audacity will try to play them all at the same time. You can stop that with the MUTE and SOLO buttons.
If you File > Export a sound file, Audacity will try to smash all the tracks into one show. You can stop that with File > Export Selected and pick the ones you want.
