Audacity not recognizing line in from RCA plugs into USB port
Help for Audacity on macOS.
Papou5
Post by Papou5 » Thu Aug 20, 2020 10:43 pm
I am ready to start recording from cassette player line out to USB port in computer but the only option in the device drop down is built in microphone. Can anyone offer help or suggestions.
Re: Audacity not recognizing line in from RCA plugs into USB port
Post by kozikowski » Thu Aug 20, 2020 11:05 pm
There's another piece of this. Those two don't plug into each other.
Could this be as simple as plugging the tape machine in first and then start or restart Audacity? Audacity should be last.
billw58
Post by billw58 » Fri Aug 21, 2020 12:50 am
Have a look at this page on the wiki.
Is this one of those $40 cassette-to-USB devices? If it shows up as "PnP USB Audio Device" in System Sound Preferences you may have trouble getting it to work reliably.
-- Bill
