Problems recording internal audio with iShowU Audio Capture
Help for Audacity on macOS.
benjamin
Post by benjamin » Wed Aug 19, 2020 2:28 am
Hi all,
Thanks for you help.
I'm attempting to capture audio files I play (but not download) in an app with Audacity and iShowU Audio Capture.
I created a Multi-Output device in the Audio Midi Setup app, checking both Built-in Audio Output & iShowU Audio Capture.
Audacity was set up as follows:
Audio Host: Core Audio
Recording Device: iShowU Audio Capture
Recording Channels: 1 Mono
Playback Device:I've tried both ' iShowU Audio Capture' & 'Built-in Output'.
I don't see any signal when play the desired track in the app and then hit record in Audacity. I assume I'm messing up the signal routing...???
Any help is a BIG HELP TO ME!!!! :cry:
Mac OS Catalina 10.15.5
Audacity 2.4.2
billw58
Re: Problems recording internal audio with iShowU Audio Capture
Post by billw58 » Wed Aug 19, 2020 2:41 am
Have a look at the instructions on this wiki page. Does that help?
You probably want to have 2 (stereo) recording channels.
-- Bill
