I'm looking to export data points with time and linear amplitude of a damped sinusoidal wave (struck instrument string). I'm only interested in analyzing the (assumed) exponential decay of the vibration's amplitude, so the envelope of the sinusoidal is really all I'm looking to export into Logger Pro/Excel. (not the wave patterning inside, just the peaks)
I found in another post here a Nyquist prompt to find the absolute peak amplitude in the time interval of one second, and it seemed very promising as I tried it out. Unfortunately, I can't yet understand code (working on it!) and, therefore, I don't know how to modify it to my purposes. I'm looking to export something along the lines of an average/peak amplitude of the sound wave in a time interval of 50-100ms. My samples are approximately 2 seconds long, and I'd need sufficient data points to be able to analyze the decay further.
So far my plans of attack have been 1) reading the amplitude and time manually and logging it into a data sheet (aLOT of grunt work) and 2) using sample data export and weeding out all but the peaks, only to find thousands of data points (more grunt work).
I don't know if what I'm trying to do makes any sense/is possible at all. Any tips or differing ideas on how to examine the decay of a sound wave? All help very welcome.
Exporting envelope of damped sinusoidal wave
Re: Exporting envelope of damped sinusoidal wave
Without getting too complicated, and assuming that you are working with a mono track, you could run this code in the Nyquist Prompt, then manually copy the data from the debug window:
If this works for you and you would like to know exactly what it is doing, I'd be happy to explain the code.
Code: Select all
;type analyze
;debugflags trace
;version 4
(setf *float-format* "%.4f") ;print with 4 decimal places
(let ((step (round (/ (snd-srate *track*) 100)))
peak-follow)
(setf peak-follow (snd-avg *track* step step op-peak))
(setf *track* nil)
(do ((val (snd-fetch peak-follow) (snd-fetch peak-follow)))
((not val) "")
(print val)))
Yes, I'm working with a mono track. It worked perfectly, thank you for the help! If you're still willing I'd be happy to learn about what the code's doing.
Super
Sure, no problem. I'll also give links to the documentation that gives more detail.
Code: Select all
;type analyze
;debugflags trace
;version 4
Code: Select all
;type analyzeCode: Select all
;debugflags traceCode: Select all
;version 4Code: Select all
(setf *float-format* "%.4f") ;print with 4 decimal placesVirtually all commands are in the form: (command arguments)
So, for example, for a simple math expression:
Y = 4 + 3
in Nyquist / LISP it would be written as:
(setf y (+ 4 3))
SETF is the command "set field", which is a general way to set the value of something. The "arguments" (parameters) are "Y" and a nested function "(+ 4 3)". Note that in the nested function, the function / command name is "+" and it's arguments are "4" and "3".
Going back to (setf *float-format* "%.4f"), we are setting the value of a special system variable *float-format" to a magic string value "%.4f". In short, it means what it says in the comment: print numbers with 4 decimal places.
https://www.audacity-forum.de/download/ ... ef-119.htm
Code: Select all
peak-follow)
(setf *track* nil)
((not val) "")
(print val)))
We create two local variables, "step" and "peak-follow".
The "step" variable is given the value (round (/ (snd-srate *track*) 100))
- When reading nested expressions like this, it's usually easiest to work from the inside (the most nested) part outwards:
Code: Select all
(setf peak-follow (snd-avg *track* step step op-peak))SND-AVG in this case, we are stepping through the *track* audio in steps of 1/100th second and looking at the peak level within each step. "peak-follow" is therefore a "sound" that has a sample rate of 100 Hz, and each sample represents the peak value of a specific 0.01 second step.
Code: Select all
((not val) "")
(print val))
Each time we loop through the code, the variable VAL is given the value of the next sample from "peak-follow".
The code loops until "NOT VAL", which means we loop until VAL is NIL.
The return value from the loop is an empty string "". This is just to keep Audacity happy that we have returned a valid value, even though that value is essentially nothing.
(print val) Each time the code loops, the value of VAL is printed. Note that in Audacity, "PRINT" will write to the debug stream, so we see the full list of printed values in the debug window.
