Audacity does not start
Help for Audacity on macOS.
NEA1971
Post by NEA1971 » Fri Aug 14, 2020 11:22 am
Hello everybody,
I just installed Audacity 2.4.2 on my Macbook pro running with Catalina 10.15.6 and I cannot get it to start.
When I start from dock I just get an popup saying something like "Audacity-Startup Error - An unresolvable error occurred during startup" (translated from German).
When I try to start the application from console I get the same popup again and following notifications inside the console
Code: Select all
open /Applications/Audacity.app/Contents/MacOS/Audacity
/Applications/Audacity.app/Contents/MacOS/Audacity ; exit;
Attempting to connect to Audacity failed...retrying
Tried to reinstall the app already and also deleting the settings-file, both didnt do any change.
billw58
Re: Audacity does not start
Post by billw58 » Sun Aug 16, 2020 2:22 am
Did you get Audacity from here: https://www.audacityteam.org/download/mac/ ?
Can you check that your SHA 256 checksum matches the one on that page?
-- Bill
NEA1971
Post by NEA1971 » Wed Aug 19, 2020 8:58 am
yes, downloaded from there and SHA256 checksum matches.
Post by steve » Wed Aug 19, 2020 9:21 am
Try deleting all three of the settings files:
  • audacity.cfg
  • pluginsregistry.cfg
  • pluginsettings.cfg
NEA1971
Post by NEA1971 » Wed Aug 19, 2020 11:37 am
  • audacity.cfg
there is only "audacity.cfg" together with a folder "SessionData", which is empty - the other two files are not there
Post by steve » Wed Aug 19, 2020 1:26 pm
What is the exact (and full) location of the audacity.cfg file?
NEA1971
Post by NEA1971 » Wed Aug 19, 2020 6:04 pm
~/Library/Application Support/audacity/audacity.cfg
Post by steve » Wed Aug 19, 2020 6:53 pm
I presume that you get the same error if you try to launch Audacity with:
Code: Select all
open -a audacity
Unfortunately I don't know much about troubleshooting on macOS. For me, Audacity 2.4.2 just works on Catalina.
Is there anything unusual or non-standard about your Mac?
What audio devices do you have?
Were you previously running an earlier version of Audacity on this machine?
Anything you can think of that might be relevant to the problem?
NEA1971
Post by NEA1971 » Wed Aug 19, 2020 8:57 pm
Code: Select all
open -a audacity
yes, I tried that one before, but same result.
steve wrote: Is there anything unusual or non-standard about your Mac?
I was installing Blackhole prior to Audacity, because I wanted to record the sound from a Language-learning program and I suspect it has something to do with my problem. I uninstalled it again, but still the same result.
steve wrote: What audio devices do you have?
standard Macbook pro 13" 2020
steve wrote: Were you previously running an earlier version of Audacity on this machine?
First time I was trying to use the software. I used it before under linux and had no issue with it.
I guess I will try resetting the macbook to default again and see if the problem is gone...
Post by steve » Wed Aug 19, 2020 9:33 pm
I don't suppose that you tried Audacity on the Mac before installing Blackhole?
