Version:
MacOS 10.13.3
Audacity 2.2.1
Hello, I've been scouring these forums and the web and while I've found it's possible, and what's supported, I can't find or figure out how I can use Python to script Audacity. Put simply what I need to do is create a script that will open a new file (New:) and start recording (Record1stChoice:), and one that will stop recording (Stop:) and export the recording with a given filename (Export2:). Could someone help or provide example code of how to work with Audacity via Python?
Thank you.
Help with Python Scripting
This forum is for Audacity 2.x.x on macOS 10.4 and later.
