Typo. No VU registering.
Mitch
USB CODEC
mitch9130
Re: USB CODEC
Hello Bill - You are amazing! It finally works. I was prepared to set a match to the turntable or sell it on Ebay. Thanks a million for not only your time, but your patience. Wish you were here, I'd give you a slab of my smoked ribs from my restaurant. Again, thanks from a dinosaur when it comes to computers.
Mitch
Mitch
billw58
Re: USB CODEC
Glad it's working. Could you tell us what step got you over the hump? Was is resetting the preferences?
-- Bill
-- Bill
mitch9130
Re: USB CODEC
Hello Bill
The issue was resolved when I reset the configuration in tools, then quit audacity and restart with turntable running. I used the drop down in recording and selected USB CODEC. The primary problem was with my Apple computer. I had to go to system preferences, security and privacy check microphone and Audacity, (I clicked the lock to unlock and make changes).
