USB CODEC
Help for Audacity on macOS.
mitch9130
USB CODEC
Post by mitch9130 » Tue Aug 04, 2020 10:58 pm
I downloaded the new audacity for my mac and noticed there is no way to access USB CODEC. I need it to record from Audio-Technica USB turntable. Has anyone else had this problem? If so, how did you resolve it. The old version of Audacity had a drop down to convert, but the new version doesn't.
billw58
Re: USB CODEC
Post by billw58 » Tue Aug 04, 2020 11:09 pm
Make sure the Device toolbar is showing. If it isn't, do View > Toolbars and make sure that Device Toolbar is checked.
If the Device Toolbar is checked in the menu but you can't see it, choose the Reset Toolbars menu item.
Plug in the turntable and make sure it is turned on. Then start Audacity. "USB Audio Codec" should appear as an option in the recording device dropdown of the Device toolbar.
-- Bill
mitch9130
Re: USB CODEC
Post by mitch9130 » Wed Aug 05, 2020 12:29 am
Hello Bill
I tried your recommendation, but my recording drop down in preferences only has Built-in Microphone
billw58
Re: USB CODEC
Post by billw58 » Wed Aug 05, 2020 1:13 am
With the turntable plugged in and turned on, go to Apple menu > System Preferences > Sound > Input. Do you see the USB Audio CODEC there?
See this page in the wiki.
-- Bill
mitch9130
Re: USB CODEC
Post by mitch9130 » Wed Aug 05, 2020 1:27 am
Yes. It is highlighted.
mitch9130
Re: USB CODEC
Post by mitch9130 » Wed Aug 05, 2020 1:32 am
Bill
I get a high pitched sound in my computer because it is picture up external sounds from my computer microphone. If I'm completely silent and attempt to play a record, I get nothing on the VU meters. My Apple preferences show USB Audio CODEC highlighted.
billw58
Re: USB CODEC
Post by billw58 » Wed Aug 05, 2020 3:10 am
Quit and restart Audacity. Can you select USB Audio CODEC in the Device Toolbar?
-- Bill
mitch9130
Re: USB CODEC
Post by mitch9130 » Wed Aug 05, 2020 3:15 am
Hello Bill
No I can't open CODEC in toolbar, but I can pick it up in Apple system preferences.
Mitch
billw58
Re: USB CODEC
Post by billw58 » Wed Aug 05, 2020 3:08 pm
Then I am at a loss to explain this. If an input is available in System Preferences > Sound > Input then it should be available in Audacity.
One last thing to try. Do Tools > Reset Configuration. Then quit Audacity. Make sure the turntable is connected and turned on. Then start Audacity. Try to select USB Audio CODEC from the recording dropdown in the Device toolbar.
-- Bill
mitch9130
Re: USB CODEC
Post by mitch9130 » Wed Aug 05, 2020 7:31 pm
Bill
I'm on the road to recovery. I now see USB CODEC in my recording drop down. I tried recording from vinyl, but still on registering on VU. Any suggestions for what I should do next?
Mitch
