Exporting MP3
Help for Audacity on macOS.
Roger Gary
Operating System: macOS 10.14 Mojave
Exporting MP3
Post by Roger Gary » Sun Aug 02, 2020 7:04 pm
I am running on MAC Mojave. Have Audacity version 2.4.2. I export as an MP3 to my seperate hardrive. However , when I access the hard drive the file isn't there. If I attempt to access the file through Audacity it shows it is in that hardrive. I am completely puzzled. I never had this problem with the precious version of Audacity.
Roger Gary
Re: Exporting MP3
Post by Roger Gary » Sun Aug 02, 2020 7:26 pm
I also noticed that when I access the file through Audacity, the file nm is listed but the file icon is grayed out!
billw58
Re: Exporting MP3
Post by billw58 » Sun Aug 02, 2020 8:03 pm
How do you "access" the external hard drive?
For the issue of the files being greyed out when you try to open them in Audacity:
- at the bottom left of the file-open dialog there is an "Options" button - click it
- this will reveal the "File types:" drop-down menu
- in that drop-down menu, choose "All files".
-- Bill
