Cannot find "Vocal reduction and isolation" under effects.
Help for Audacity on macOS.
lm33
Operating System: macOS 10.14 Mojave
Post by lm33 » Mon Jul 27, 2020 10:07 pm
I am using macOS sierra and have audacity version 2.1.1 and cannot find the "vocal reduction" effect, is there a plug in I need to download?
billw58
Re: Cannot find "Vocal reduction and isolation" under effects.
Post by billw58 » Mon Jul 27, 2020 11:17 pm
First, consider upgrading to Audacity 2.4.2.
Second, you may need to enable the effect using the Plug-ins Manager.
-- Bill
