Graillon 2 EQ doesn't disply rich interface
Help for Audacity on macOS.
Fred50
Post by Fred50 » Sun Jul 26, 2020 7:57 pm
Greetings! I have High Sierra (10.13.6) with Audacity 2.3.3. Installed the free Graillon 2 Equalizer (AU) in Components and Enabled. When I apply the effect to a track, I get only a gray box with three transport buttons and an Apply button. I have restarted Audacity and reinstalled Graillon. No change. Has anyone else run into this problem? Am I doing something wrong? (Entirely possible!). Many thanks for any assistance!
billw58
Re: Graillon 2 EQ doesn't disply rich interface
Post by billw58 » Sun Jul 26, 2020 10:56 pm
Where did you get that? I can only find the Graillon 2 Vocal Changer.
Have you tried changing the interface setting? Scroll to the bottom of the page to "Audio Unit Effect Options". Under "User Interface" try "Generic". Close the settings dialog, close the effect dialog then open the effect dialog again.
Upgrading to Audacity 2.4.2 might help.
-- Bill
Fred50
Post by Fred50 » Mon Jul 27, 2020 7:02 pm
Ah, you're right. It is listed as Voice Changer. I found it while looking for various free autotune options. I know Audacity has one as well. Thanks so much for responding so quickly!
billw58
Post by billw58 » Mon Jul 27, 2020 9:32 pm
So this issue is resolved for you?
-- Bill
