Trying to record singing with imported music
Help for Audacity on macOS.
valsurfer
Post by valsurfer » Fri Jul 24, 2020 7:10 pm
I am brand new at this and I am trying to add singing of the lyrics to a downloaded karaoke song. I have MAC 10.15.5 and Audacity 2.4.2. I imported the song and when I hit record to sing, there is no audible music from speakers or if I plug in earbuds, although I can see the track is playing. The singing recording jumps to where it looks like it is starting at the end of the song in a "window" below the imported track, nothing like what I have seen in YouTube instructional videos. I can play the imported song, but when I hit record, everything changes. Any help would be greatly appreciated.
billw58
Re: Trying to record singing with imported music
Post by billw58 » Fri Jul 24, 2020 10:22 pm
First, make sure you have "Play other tracks while recording" checked in Recording Preferences.
Second, make sure that "Record on a new track" is NOT checked.
You will not be able to hear your voice in the headphones.
When you're finished, the voice track will be out of sync with the music track unless you first set the latency adjustment as explained here. If you don't want to go through setting the latency adjustment you can manually move the voice track using the Time Shift tool.
-- Bill
