Recording cassettes doesn't work
Help for Audacity on macOS.
L7QeGvjA*[email protected]
Post by L7QeGvjA*[email protected] » Fri Jul 10, 2020 2:05 pm
I'm trying to record a bunch of old compact cassettes using a device called SUPER USB CASSETTE CAPTURE. It's one of those generic ones I've bought on Amazon. I've connected it using the official Apple USB-A to USB-C adapter on my 2018 MacBook Pro as it came with a Mini-B to USB-A cable.
In System Preferences and Audio MIDI Setup it randomly shows up for a second or two and then disconnects for another 5 until it reappears again and so on. I did manage to connect it to Audacity after some trial and error where it shows up as USB PnP Audio Device, however it won't record as there's an Error opening recording device with Error code: -9997 Invalid sample rate. I've tried using different sample rates but none of them work.
I did manage to somehow get it to record before (not sure how) but Audacity just randomly stopped recording after about 11 minutes for no apparent reason so I then tried using my old 2012 MacBook Pro if it would be any different on there but nope, same issue as above except with Error code: -9986 Internal PortAudio error. I've now reconnected it to my 2018 MacBook Pro but now I'm back to square one. This is just beyond ridiculous and frustrating!
I'm using Audacity 2.4.2 on macOS 10.15.5.
billw58
Re: Recording cassettes doesn't work
Post by billw58 » Fri Jul 10, 2020 5:27 pm
It shows up as a "PnP USB Audio Device" right? I don't know anyone who has got one of those to work reliably on Mac.
-- Bill
Post by L7QeGvjA*[email protected] » Fri Jul 10, 2020 8:16 pm
What do you suggest? Should I try it in a virtual machine running Linux?
DVDdoug
Forum Crew
Post by DVDdoug » Fri Jul 10, 2020 9:14 pm
If you've already got Linux running it's worth a try. Otherwise, it's probably not worth the effort.
Another possibility is a USB audio interface with line-inputs (connected to the cassette player's headphone-out). Or, you can use an interface if you have an older stereo with a cassette player you can use that (with line-output, recording-output, headphone-output, etc.).
There are a few suggestions on this page or there are lots of higher-end interfaces with switchable mic/line inputs. Do NOT buy a regular little "USB soundcard". They are like laptops with only mic-in and headphone-out.
From what I see on the forum they are often flaky on a PC too... I doubt they are 100% reliable on Linux.
Post by L7QeGvjA*[email protected] » Fri Jul 10, 2020 9:47 pm
Hmm, I do have a FiiO Q1 Mark II DAC/headphone amp, would it be possible to use a 3.5mm to 3.5mm aux cable to connect it on there? Would that work?
DVDdoug
Forum Crew
Post by DVDdoug » Fri Jul 10, 2020 9:58 pm
No... You need an ADC, not a DAC. ;)
Post by L7QeGvjA*[email protected] » Fri Jul 10, 2020 10:10 pm
How would that setup work?
DVDdoug
Forum Crew
Post by DVDdoug » Sat Jul 11, 2020 1:41 am
If you were using the Berhinger UCA202 interface the headphone output from the cassette player goes to the analog inputs on the interface (with appropriate cables/adapters) and the interface connects to the computer via USB.
An interface is similar to a soundcard. It has an ADC for recording and a DAC for playback.
Post by L7QeGvjA*[email protected] » Sat Jul 11, 2020 6:07 am
Hmm, it seems like that one isn't available here unless I import it which would be rather expensive and time consuming. I've found this one on Amazon though: https://www.amazon.de/V-TOP-Audio-Grabb ... uage=en_GB Would that one work? Also on Mac? Even with the USB-A to C adapter, would that cause any issues?
billw58
Post by billw58 » Sun Jul 12, 2020 2:26 pm
The description says it works with macOS. I can't guarantee anything, though, having never used it.
-- Bill
