need help with system settings for recording audio
Help for Audacity on macOS.
[email protected]
Post by [email protected] » Wed Jul 01, 2020 4:19 pm
Been trying to record audio from Pandora on my computer and tried just about everything possible without success
I have a iMac (27-inch) with High Siera that works with all graphic and design programs
Added Soundflowerbed.app as suggested but nothing works.
I collected about 20 recording applications, some free and some paid for and I have the same problem with all.
Can anyone please help me with the settings or some advise?
Thanks
Dan D
billw58
Re: need help with system settings for recording audio
Post by billw58 » Wed Jul 01, 2020 10:22 pm
Soundflowerbed is an app that helps make settings for the system addition called Soundflower. Soundflower has not been supported for many years.
Does anything on this page help?
-- Bill
Post by kozikowski » Wed Jul 01, 2020 11:40 pm
Still. It does work on two of my machines.
Right. That's why I'm still on High Sierra. I posted my installer a little bit ago. I'll see if I still have it.
Post by kozikowski » Wed Jul 01, 2020 11:41 pm
Down at the bottom of this post.
viewtopic.php?f=47&t=111908
