Cassette to Mac - audacity file is faster with lots of signal noise
Help for Audacity on macOS.
praudacity
Post by praudacity » Sun Jun 28, 2020 11:18 pm
macOS 10.13.6
Audacity 2.4.1
I'm using Audacity for the first time. I'm using a Sony Walkman Professional with M-AUDIO Fast Track Pro interface.
I recorded a stereo track from the cassette source material. In the Audacity file, the pitch is slightly elevated and vocals are a bit sped up a la The Chipmunks. The quality of the Audacity track has lots of crackling.
Any ideas?
Peter
Re: Cassette to Mac - audacity file is faster with lots of signal noise
Post by kozikowski » Mon Jun 29, 2020 12:11 am
Did the Fast Track come with software and did you install it?
That's not necessarily a good thing. The Fast Track should just plug in to the Mac and go. If you configured their software wrong, you could have a mismatch between the Fast Track and Audacity.
Control+Tap or Right-Click the sound file > Get Info. Look down the Info panel to More Info, Sample Rate. What does it say?
billw58
Post by billw58 » Mon Jun 29, 2020 12:12 am
Check in Audio-MIDI Setup that the Fast Track is operating at the same sample rate as Audacity.
This page in the wiki might help.
-- Bill
Post by kozikowski » Mon Jun 29, 2020 12:17 am
Desktop > Go > Utilities > Audio/MIDI Setup.
