export issue
Help for Audacity on macOS.
Mrkil1o1
export issue
Post by Mrkil1o1 » Fri Jun 26, 2020 3:23 pm
First off I'm not a terribly technical person so, please, put any answer/explanation in terms I can understand.
I don’t understand what would cause me to receive this warning when trying to export a track: “can’t open audio codec aac 0x15002” when I did this operation all the time in previous versions.
Audacity v. 2.4.1 on Mac
macOS 10.15.5
billw58
Re: export issue
Post by billw58 » Fri Jun 26, 2020 4:57 pm
This bug has been fixed in Audacity 2.4.2, just released today!
-- Bill
Mrkil1o1
Re: export issue
Post by Mrkil1o1 » Sun Jun 28, 2020 4:57 pm
thanks
