Keeps crashing
Help for Audacity on macOS.
damaranai
Keeps crashing
Post by damaranai » Sat Jun 20, 2020 1:41 am
Hello, I'm on High Sierra and using Audacity 2.4.1.
I'm trying to edit a podcast and have 2-3 tracks and editing and my Audacity keeps crashing.
There is an error report but I'm not sure how to read it/what to look for.
When I reopen Audacity they ask me if I want to recover - I say yes, and save it immediately before I do anything.
But then within 1-2 minutes it crashes again.
Can you advise what to look for?
Thank you!
billw58
Re: Keeps crashing
Post by billw58 » Sat Jun 20, 2020 2:34 pm
Step 1 - reset Audacity's settings using the instructions here: viewtopic.php?f=47&t=101842
Then open the project and try to do some editing.
If that doesn't work we can assume there is a problem with the project itself.
Step 2
Open the project, but don't try to do any editing.
(We're going to export each track as an AIFF, then import those files into a new project)
Do File > Export > Export Multiple
- choose a place to save the files
- set Format to AIFF
- Set "Split files based on:" to "Tracks"
- If your tracks do not have unique names, set "Name files:" to "Numbering before Label/Track name"
- click "Export"
When the export is finished, close the project, make a New project, then import the files into the new project.
-- Bill
damaranai
Re: Keeps crashing
Post by damaranai » Mon Jun 29, 2020 10:26 pm
Hi Bill, Thank you so much for your help. Sorry, I didn't realize there's a comment on this thread until today.
I'm working on a different project from the one I originally posted about in my OP, but having a same problem so I came back here to find your comment.
First of all, resetting Audacity did nothing.
What happens is (I produce podcasts), when I line up several tracks and when I try to record something it crashes.
I did try your Step 2 and so far it is working. I recored something on top of the project, and it did not crash and it lets me keep working on it.
I have 2 podcasts. Few days ago I worked on the other podcast project (let's call it podcast B)and had no issue. Just edit as usual, add some music, and export.
Today I started on the other podcast (the one I had problem with initially on June 19 - Podcast A) - different episode.
As soon as I line up the tracks (interview and music) then try to add new track where I make commentary, it crashes.
I have a weird feeling maybe it's related to the music track I insert? (opening theme music) Could it be possible?
Anyway, sorry for rambling on, I don't think it's the Audacity issue because I managed to work on Podcast B fine, but when i try to work on Podcast A, it crashes. Both are interview style podcast where I use recorded conversation from zoom, but the difference is the opening theme song and language (which i don't think anything to do with the issue).
I am happy the current podcast A project is working, however what happens when I work on the next week's episode? Do I have to do the same export as AIFF? Ideally I'd like to solve this so that I don't have to do the export every time I work on podcast A.
Thank you so much.
billw58
Re: Keeps crashing
Post by billw58 » Tue Jun 30, 2020 12:23 am
Glad you got it working.
From your description is sounds like the AUP file for the "original podcast A" was corrupted. That's why I asked you to export all the tracks and bring them into a new project.
-- Bill
billw58
Re: Keeps crashing
Post by billw58 » Tue Jun 30, 2020 12:37 am
Would you mind attaching the AUP file of the project that kept crashing (podcast A?) to a reply in this thread? There is no audio in the AUP file, just a bunch of text that tells Audacity how to line everything up. If we can figure out what is wrong with the AUP file it may help us squash a bug.
Thanks.
-- Bill
