.m4a greyed out in file/import/audio, but can open from Finder
Help for Audacity on macOS.
mattwallis
Operating System: macOS 10.14 Mojave
Post by mattwallis » Fri Jun 19, 2020 6:19 am
Audacity 2.4.1. Max OS 10.14
From the Finder, I can open .m4a files in audacity, using Finder's 'open with'.
But in audacity, when I choose File/import/audio, .m4a files are greyed out in the file selection dialogue box.
I've only just installed 2.4.1, but this worked on previous versions on my Mac.
Re: .m4a greyed out in file/import/audio, but can open from Finder
Post by steve » Fri Jun 19, 2020 9:40 am
Ensure that "All files" is selected in the file browser.
mattwallis
Post by mattwallis » Mon Jun 22, 2020 7:58 am
Doh! Silly me. My excuse: I think in earlier versions, the File Type drop-down was always visible in the file-chooser dialog, whereas now it is 'hidden' behind an 'Options' button. I'd got used to scanning the bottom of the dialig box to check which file types were selected.
