i get this error
"Audacity Startup Failure"
"An unrecoverable error has occurred during startup"
and in terminal if i try to open it there i get
"/Applications/Audacity.app/Contents/MacOS/Audacity ; exit;
Attempting to connect to Audacity failed...retrying
[Process completed]"
can anyone help?
2.4.1 Will not run on MacOS 10.15
billw58
Re: 2.4.1 Will not run on MacOS 10.15
Please reset the Audacity settings as explained here: viewtopic.php?f=47&t=101842
If that does not help, check the following.
Did you download Audacity from this site: https://www.audacityteam.org/download/mac/ ?
Please check the SHA checksum according to these instructions:
https://www.audacityteam.org/download/o ... /#validate
-- Bill
-- Bill
