Migrating from Windows, can't get VSTs installed
Help for Audacity on macOS.
thatjackelliott
Post by thatjackelliott » Thu Jun 18, 2020 12:59 am
I'm helping my wife shift from a Windows PC to a new Mac. She has a small suite of VSTs that she uses to produce her weekly radio show. These have been dialed in to get the sound she wants and I'd like her new environment to give her the familiar sound. Problem is, following the instructions at https://manual.audacityteam.org/man/ins ... t_install , no matter where I put the plug-ins, relaunch Audacity and go to Manage Plugins, the VSTs are not showing up as New. So.
Catalina 10.15.5, Audacity 2.4.1
Right now I have the target VST .dlls in:
~/Library/Application Support/audacity/Plug-Ins
/Library/Audio/Plug-Ins/Components
/Library/Audio/Plug-Ins/VST
And no dice. Audacity denies that they are available.
Oh -- one thing -- that page on manual.audacityteam.org says to try "All paths specified by the "VST_PATH" environment variable." printenv does not show a VST_PATH environmental variable.
Anyway, how can I get Audacity to find the VSTs?
Thank you!
billw58
Re: Migrating from Windows, can't get VSTs installed
Post by billw58 » Thu Jun 18, 2020 2:15 am
Do you have the Mac versions of the VST effects?
-- Bill
thatjackelliott
Post by thatjackelliott » Thu Jun 18, 2020 5:13 am
Oh jeez. No, they are the Windows versions. Duh.
Well, that clears up THAT mystery!
Thanks!
