Can't Enable mod-script-pipe
Help for Audacity on macOS.
suppotMP
Post by suppotMP » Sun Jun 14, 2020 1:21 pm
Hi there!
I'm trying to Enable mod-script-pipe in Mac (Catalina) with the Audacity last version.
Going to Modules, Enable mod-script-pipe , save and Restart Audacity.
But when launch again Audacity first show an error: Non properly module. Is not posible to load the module "mod-script-pipe. Error no such file or directory
Also there's no /tmp/audacity_script_pipe.from... file (but it is /tmp/audacity_script_pipe.to.501).
Can somebody help me to Enable it.
Thank you and best regards
Re: Can't Enable mod-script-pipe
Post by steve » Sun Jun 14, 2020 8:26 pm
Which version of Audacity?
suppotMP
Post by suppotMP » Tue Jun 16, 2020 2:34 pm
Hi Steve,
I'm using Audacity 2.4.0
Thank you
Post by steve » Tue Jun 16, 2020 3:49 pm
suppotMP
Post by suppotMP » Fri Jun 19, 2020 7:12 am
Hi Steve!
Enabling mod-script-pipe works fine on Audacity v2.4.1.
Thank you very much!!
