audacity 2.4.1 not recording anything
Help for Audacity on macOS.
elfin
Post by elfin » Thu Jun 11, 2020 10:04 pm
Have Catalina 10.15.5 Cannot get anything to record thru mic or system audio. Went to sys prefs/ privacy security and mic is on for Audacity. Checked my sound settings and all is fine. Settings for input in Audacity are set correctly. Where do I go from here?
minyrva
Re: audacity 2.4.1 not recording anything
Post by minyrva » Sat Jun 13, 2020 3:10 am
Is your mic working at all? Can you record sound in other programs, such as Quicktime?
