Hi,
Does anyone know If there Is there a program that can Extract Drums (Only) from an MP3?
For Example : Pro Tools, Audacity PlugIn, or any other program?
Thanks All!
Is there a program to Extract Drums (Only) from an MP3?
Waynard1962
Re: Is there a program to Extract Drums (Only) from an MP3?
Audacity can't split a mixed song into individual instruments, voices or sounds.
