ACX Check Plugin won't install on Mac OS Catalina
amytheangel81
I am a new user. I read that it was recommended to install the ACX Check plugin. When I try to install on my Mac OS Catalina it says there are no apps to open the document "acx-check-ny." How do I get it to install? Am I trying to download the wrong plugin? Thank you.
Re: ACX Check Plugin won't install on Mac OS Catalina
I'm not a Mac user, but the instruction are here.
