ACX Check fails in 2.4.1
Help for Audacity on macOS.
Re: ACX Check fails in 2.4.1
Post by kozikowski » Fri Jun 05, 2020 11:08 am
This is a result of analyzing a noise segment only. No actual performance.
I'm assuming this is a sampling oddity. Still, that should be impossible.
Post by steve » Fri Jun 05, 2020 11:11 am
That's probably because of this: viewtopic.php?p=396709#p396709
I'll fix that.
Post by kozikowski » Sat Jun 06, 2020 12:12 pm
I'll fix that.
Is there new test code?
I'm waking up a Win7 machine out of hibernation to do testing. No Win10. Sorry.
Post by steve » Sat Jun 06, 2020 4:48 pm
Here's the new test code:
Code: Select all
;version 4
;type analyze
;debugflags trace
(defun getfloor (sig &aux (chunk 30))
  ;; Return guestimate of noise floor.
  ;; 'sig' is theRMS level and has around 10 Hz sample rate,
  ;; We look for the lowest 0.1 s block as the local 'floor'
  ;; Return a label for each calculated 'floor'
  (let ((floor 999)
        (floor-labels ())
        (chunkcount 0)
        label
        (start 0)
        (srate (snd-srate sig)))
    (setf chunk (1- (* chunk srate)))  ;chunk size in samples
    (do ((val (snd-fetch sig) (snd-fetch sig)))
        ((not val))
      (cond
        ((<= chunkcount chunk)
            (incf chunkcount)
            (when (< val floor)
              (setf floor val)))
        (t  (setf label (list (/ start srate)
                              (/ (+ start chunkcount) srate)
                              (format nil "~a" (round (linear-to-db floor)))))
            (setf start (+ start chunkcount))
            (setf chunkcount 1)
            (push label floor-labels)
            (setf floor val))))
    (push label floor-labels)))
(defun to-mono (sig)
  ;;; coerce sig to mono.
  (if (arrayp sig)
    (s-max (s-abs (aref sig 0))
           (s-abs (aref sig 1)))
    sig))
(defun stereo-rms(ar)
  ;;; Stereo RMS is the root mean of all (samples ^ 2) [both channels]
  (let ((left-mean-sq (* (aref ar 0)(aref ar 0)))
        (right-mean-sq (* (aref ar 1)(aref ar 1))))
    (sqrt (/ (+ left-mean-sq right-mean-sq) 2.0))))
;; This test is only required when running in the Nyquist Prompt
(if (< len 1)
    "No audio selected."
    (progn
      (setf rms
        (let ((rms (get '*selection* 'rms)))
          (if (arrayp rms)
              (linear-to-db (stereo-rms rms))
              (linear-to-db rms))))
      (setf peak (linear-to-db (get '*selection* 'peak-level)))
      (format t "Peak level:  ~a dB.~%~
                  RMS level:  ~a dB.~%"
              peak
              rms)
      (let ((sig (rms (to-mono *track*) 10))) ;Approx 10 Hz sample rate
        (setf *track* nil)  ;free *track* from memory
        (getfloor sig))))
Post by kozikowski » Sat Jun 06, 2020 5:38 pm
;version 4
Version 4 of Nyquist, or this is release 4 of the code?
Post by steve » Sat Jun 06, 2020 5:54 pm
Yes.
As soon as we have a plug-in version I'll add a plug-in version number.
Post by kozikowski » Sun Jun 07, 2020 1:41 am
This is an 84 minute simple voice performance. I measured it in 20 minute chunks and it passes with noise hovering in the -61dB to -62dB range.
Screen Shot 2020-06-06 at 18.25.50.png (39.55 KiB) Viewed 194 times
This is the new code.
Screen Shot 2020-06-06 at 18.34.37.png (121.68 KiB) Viewed 194 times
Post by kozikowski » Sun Jun 07, 2020 2:03 am
How about you wrote "Noise Sleuth." If the performer fails Legacy ACX Check, run Noise Sleuth to help sort what happened and where.
Post by steve » Sun Jun 07, 2020 12:47 pm
I like that idea.
I also think that it could be built into one plug-in.
Three possible alternatives:
1.
The plug-in would have a simple GUI with a choice control: "Simple" / "Noise Sleuth".
The "Simple" option just gives you a single result for Noise Floor.
The "Noise Sleuth" option produces the labels.
2.
The plug-in runs without a GUI (as with the old effect).
It gives a simple single result for each of: Peak / RMS / Floor
AND the labels.
3.
The plug-in runs without a GUI.
It also labels any regions greater than "x" seconds that have a noise floor that is out of range (> -59 dB or < -90 dB).
I'm not sure what the best value for "x" should be, but I'd guess around 30 seconds.
One important question: Precisely what should the one result "legacy test" measure? The lowest 0.5 second RMS in the first 5 seconds?
Post by kozikowski » Mon Jun 08, 2020 4:08 pm
Working on it.
I think what concerns me is the software binning a 90 min performance because of one perceived violation. A violation that we have every expectation that nobody else will ever find. By that measure, no home reader will ever pass noise.
But they do. Using Mastering and Legacy ACX Check, people get published all the time.
Maybe the readers will have to settle for a vacation villa on the Scottish coast. Côte de Gris.
