Audacity won't record
Help for Audacity on macOS.
wscofield77
Post by wscofield77 » Wed May 20, 2020 8:54 pm
Hello,
I am new here. Trying to record some vocal audio. Just purchased a new USB mic but cannot get audacity to record at all. Here is the relevant info that I know of:
Running OS 10.15.4
Restarted audacity several times
My new mic is selectable in the drop down menu
even the built in mic will not record for some reason.
I uninstalled audacity and did a fresh install. Still didn't work.
Please let me know if something comes to mind. I really appreciate any help you can give. thanks
jotasprout
Re: Audacity won't record
Post by jotasprout » Thu May 21, 2020 1:48 pm
I came in here with the same and other problems -- take a look at the most recent posts in this forum and several are about Audacity in new Mac OS with some workarounds.
viewtopic.php?f=47&t=107293
viewtopic.php?f=47&t=108755
viewtopic.php?f=47&t=108270
and others
