audacity is making a weird noise
Help for Audacity on macOS.
aazarshad
Operating System: macOS 10.11 El Capitan
Post by aazarshad » Sun May 17, 2020 4:52 pm
hey folks,
I just started recording my first podcast. I imported an audio but somehow the sound does not give a clear voice. There's nothing wrong with the audio.
I'm unsure what happened. I'm sure it's audacity. Do you know how to fix this?
Re: audacity is making a weird noise
Post by steve » Sun May 17, 2020 5:00 pm
"weird noise", "not clear". That does not tell us enough to be able to offer any help.
How are you listening to your Audacity project?
Why do you think there is a problem?
aazarshad
Post by aazarshad » Sun May 17, 2020 6:06 pm
Thanks for getting back so quick.
It's a distorting music and I keep hearing myself. Somehow in when I export it the noise is gone.
I don't know how to explain, I can attach an audio for an example.
