Broken Project (Orphan Block Files / missing audio)
Help for Audacity on macOS.
RadioPlayTeacher1
Post by RadioPlayTeacher1 » Fri May 15, 2020 6:11 pm
Hello! My program crashed while running an equalization and after a force quit, the project and the recovered project were both missing the audio.
All the files in the data folder seem to be missing the audio as well. The odd thing is the track spacing and all the envelope tool work is still there.
Is this project toast or is their anything I can do?
I attached the project and screenshots
log.txt
(27.71 KiB) Downloaded 5 times
Rehearsal for Murder (Part 3) (BROKEN).aup
(158.66 KiB) Downloaded 3 times
Screen Shot 2020-05-15 at 11.09.38 AM.png (756.35 KiB) Viewed 61 times
Screen Shot 2020-05-15 at 11.09.22 AM.png (806.11 KiB) Viewed 61 times
RadioPlayTeacher1
Re: Broken Project (Orphan Block Files / missing audio)
Post by RadioPlayTeacher1 » Fri May 15, 2020 7:09 pm
To clarify, this is Audacity 2.3.2 on Mac High Sierra (10.13.6)
Post by steve » Fri May 15, 2020 7:10 pm
I think it's toast. To reduce the chance of it happening again, I'd suggest that you update Audacity.
The current version is 2.3.3, though Audacity 2.4.0 is due to be released very soon.
RadioPlayTeacher1
Post by RadioPlayTeacher1 » Fri May 15, 2020 9:23 pm
Dang. I appreciate the quick response! I'm just redoing the work then.
