can't find the punch copy paste Nyquist plugin
Help for Audacity on macOS.
sunlight10
Operating System: macOS 10.14 Mojave
Post by sunlight10 » Mon May 11, 2020 10:47 pm
Hi! I have a MAC Mojave V10.14.6 and am using Audacity 2.3.3. I've read about punch copy paste and would love to use it, but I can't find the plugin anywhere. I look at the list of available Nyquist plugins in the manual, and it's not there. Thanks for your help!
billw58
Re: can't find the punch copy paste Nyquist plugin
Post by billw58 » Tue May 12, 2020 2:11 am
Is this what you're looking for?
viewtopic.php?f=42&t=71556#p208312
-- Bill
sunlight10
Post by sunlight10 » Tue May 12, 2020 1:15 pm
I'm sure it is - thank you so much!!
Ohimu San
Post by Ohimu San » Thu May 14, 2020 4:58 am
Did you actually find the punch copy/ paste plug in and does it work on your Audacity 2.3.3.? I have exactly the same system (mac OS 10.14.6) and desperately looking for that plug in. I know Audacity itself has replaced it with Punch roll for the recording purposes, but I need punch copy / paste for editing purposes.
Post by steve » Thu May 14, 2020 2:22 pm
See the last post by billw58.
