lame.buanzo.org is down and I can't access the package (fmpeg_64bit_osx.pkg).
I also have downloaded so many files but none of them contain ffmpeg.55.64bit.dylib which is the needed file!
I really desperately need to be able to get the FMPEG working to open files ASAP
Need help with downloading FMPEG 64-bit for Audacity
Re: Need help with downloading FMPEG 64-bit for Audacity
