No File, Edit, Select, View etc on my 2.3.3 dowload
Help for Audacity on macOS.
revald
Post by revald » Sun May 10, 2020 5:05 pm
Hi, I recently downloaded the most recent Audacity 2.3.3 onto my Mac OS High Sierra version 10.13.6 but there is no top line facility ie File, Edit, Select, View etc and the only way I can save is to audacity itself. I also installed the 2.3.3 on my Windows laptop and the top line facility was there, so I was able to export my file as an mp3 which is what I want to do. Can anyone help please? I'm not highly technical but not too bad either :) Thanks in advance.
billw58
Re: No File, Edit, Select, View etc on my 2.3.3 dowload
Post by billw58 » Sun May 10, 2020 5:48 pm
When Audacity is running but no project window is open, only the Apple, Audacity and File menus are available.
Do you have Audacity in full-screen mode?
-- Bill
revald
Post by revald » Sun May 10, 2020 6:09 pm
Hi Bill, thanks for reply. I tried Full Screen but nothing changed. There is nothing above the pause, play, record buttons etc. except a thin frame with the centred word Audacity. The only way I even got to save the recording at all was when I clicked to leave and it asked if I wanted to save it. I took a screenshot but not sure whether I can post that here. Can't see an insert image section. Thanks.
billw58
Post by billw58 » Sun May 10, 2020 7:23 pm
Please reset your preferences according to these instructions: viewtopic.php?f=47&t=101842
You only need to delete the "audacity.cfg" file.
-- Bill
revald
Post by revald » Sun May 10, 2020 9:36 pm
Many thanks Bill. I did what you suggested and relaunched but still no top line for File, Edit...etc. Perhaps I need to uninstall and reinstall?
Post by steve » Sun May 10, 2020 9:49 pm
Are you new to macOS? Are you aware that it is normal for applications on macOS to have their menus at the top of the display rather than at the top of the application window?
revald
Post by revald » Mon May 11, 2020 7:01 am
Hi Steve, thanks for reply. Yes, new to using Audacity on Mac. I shut the whole thing down last night and this morning, et voila, I saw the display at the top! It may well have been there yesterday and I just didn't 'see' it because I thought it was the regular menu bar. Also I just noticed that when full screen no top menu of any kind is there at all until I point the cursor into the top left corner. Whatever the reason, it's all good now and thank you very much for your help.
Post by steve » Mon May 11, 2020 8:59 am
Also, it is only there when the application has focus. As soon as you click on another application, that application's menu bar replaces the previous menu bar. It makes working with multiple applications at the same time quite tedious in my opinion.
Another thing to watch out for (in case you haven't noticed yet); When you close an application on a Mac, the application continues running in the background. To stop the application running, you have to explicitly "Quit" or "Exit" the application - just "closing" it isn't enough.
revald
Post by revald » Mon May 11, 2020 10:56 am
Thanks for that additional info Steve, very helpful. I shall make sure I Quit when I finish with an app!
Have a great week.
