OSX upgrade
Help for Audacity on macOS.
Minder136
OSX upgrade
Post by Minder136 » Sat May 09, 2020 1:20 pm
I have upgraded to OSX 10.13.6 from Yosemite and cannot open Audacity because of the 32-bit issue. My Audacity version is 2.2.1.
Re: OSX upgrade
Post by kozikowski » Sat May 09, 2020 1:43 pm
My Audacity 2.3.3 opens in High Sierra (10.13.6) OK. You may have other issues.
Mojave 10.14.x complains about 32-bit and Catalina 10.15.x just stops working.
Why do you think it's a 32-bit issue?
Re: OSX upgrade
Post by steve » Sat May 09, 2020 2:17 pm
Audacity 2.3.3 for macOS is 64-bit: https://www.audacityteam.org/download/mac/
waxcylinder
Re: OSX upgrade
Post by waxcylinder » Sat May 09, 2020 3:39 pm
Audacity 2.3.3 actually launches and runs on Catalina. it just won't record as Catalina will not grant it access ro the mic to record as the app is not "notarized" a new higher gating factor that Apple brought in with Catalina.
There is a workaround using a launch of Audacity from the Terminal app: viewtopic.php?f=47&t=107162
This is fixed for the soon to be upcoming 2.4.0 as we now have the Audacity app notarized with Apple.
Peter.
Re: OSX upgrade
Post by kozikowski » Sat May 09, 2020 5:37 pm
You still got something else wrong. This is my Audacity 2.2.1 running, and recording in High Sierra.
Screen Shot 2020-05-09 at 10.34.24.png (63.25 KiB) Viewed 70 times
