Can't find EQ XML to TXT Converter to enable in Manage Plugins
Help for Audacity on macOS.
ajs8
Operating System: macOS 10.14 Mojave
Post by ajs8 » Fri May 08, 2020 6:52 am
macOS mojave, Audacity 2.3.3
I want to enable "EQ XML to TXT Converter" in "Manage plug-ins" but it doesn't exists. I read that this was preloaded, but not enabled. However, I don't see it. I want to enable it so that I can download Filter/EQ Curves. Thanks
waxcylinder
Re: Can't find EQ XML to TXT Converter to enable in Manage Plugins
Post by waxcylinder » Fri May 08, 2020 6:56 am
Because it's a new feature for the soon to be released Audacity 2.4.0 - it's not in 2.3.3
ajs8
Post by ajs8 » Fri May 08, 2020 6:58 am
What do I do now then to download and enable EQ Curves?
waxcylinder
Post by waxcylinder » Fri May 08, 2020 7:02 am
You can't with 2.3.3 as there is no Import available in the EQ effects.
2.4.0 is scheduled for release early next week (provided we don't find any more major bugs).
If you wish to experiment and help us test the release candidate yo can download it fom here:
https://www.fosshub.com/Audacity-devel.html
ajs8
Post by ajs8 » Fri May 08, 2020 7:05 am
Great! thanks, I'll wait for the new release!
