I hit record and nothing happens
Help for Audacity on macOS.
KevRuzz
Operating System: macOS 10.11 El Capitan
Post by KevRuzz » Mon May 04, 2020 1:33 am
I'm experiencing an issue when recording on my Mac (10.11.5 El Capitan). I've recorded on this device dozens of times before without issue.
I open a new project, I hit record, a new track forms, but the pin does not move. Nothing is recording.
I tried uninstalling and re-installing and it's the same thing.
Re: I hit record and nothing happens
Post by steve » Mon May 04, 2020 11:59 am
Has this problem appeared after a Mac update? (See: https://osxdaily.com/2011/10/25/check-w ... -mac-os-x/)
KevRuzz
Post by KevRuzz » Mon May 04, 2020 10:58 pm
I checked the updates log, there doesn't seem to be anything out of the ordinary.
Some additional info:
-I use a Blue Yeti microphone. I happened to have a second but the results are the same.
-When I switch to from "Yeti" to "Built-in input", it DOES record, but that's not the sound quality I need.
Post by steve » Tue May 05, 2020 9:17 am
That's useful information - rules out several possibilities.
In the system sound settings, if you select the Yeti as the recording device, do you see a signal level when you talk into the mic?
KevRuzz
Post by KevRuzz » Sat May 09, 2020 11:10 pm
It appears to be working now. *shrug* :D
