Missing Audio Data Block Files
Help for Audacity on macOS.
MDuke611
Post by MDuke611 » Wed Apr 15, 2020 12:08 am
When I open one of my projects in audacity (which was working fine an hour or so ago), the following error message appears:
"Warning - Missing Audio Data Block File(s)
Project check of "bb_questionsanswers_synced_data" folder detected 82 missing audio data (.au) blockfile(s) probably due to a bug, system crash, of accidental deletion. There is no way for Audacity to recover these missing files automatically."
It then gives me 3 options:
a) close project immediately with no further changes
b) Treat Missing audio as silence (this session only)
c) Replace missing audio as silence (permanent immediately)
When I chose option a, the program just closes and the exact same thing appears when I reopen, when I chose option b, seconds of my audio disappear, and I haven't tried option c, because I don't want to lose my audio.
How do I fix this? When I click on the log to show details, the program just freezes. I've never moved these files or this project, it just lives on my external hard drive. I have Catalina and version 2.3.1 TIA!
Re: Missing Audio Data Block Files
Post by steve » Wed Apr 15, 2020 10:13 am
Option "b) Treat Missing audio as silence (this session only)" is probably as good as it gets.
Was the project on remote storage? (example: dropbox)
If it was, then you could try re-syncing the local version from the remote version.
(I would advise against using remote storage as it frequently has problems when dealing with very large numbers of small files).
If the above does not help, and if the "good" audio in the project is worth keeping:
Restart Audacity, select option (b) and save the project with a new name (use "Save Project As...")
kiechkechai
Post by kiechkechai » Thu May 14, 2020 5:52 pm
Hi,
I've exactly the same problem, wasting 3 weeks of work ! I'm so :twisted:
It seems that nobody has a solution !?
Heeeeeeelp...
